Well this has me confused as hell. I have the amp hooked up to a 12w7 all 4ga. for grounds and power, the ground is hooked up to a seatbelt bolt. 12ga. for the speaker wire. I also have a cap hooked up in there.
Alright well the problem came about when i had everything turned up pretty good, doors shaking etc., the cap said it had about 11.9 volts going through it and then all the sudden it started beeping and the volts started dropping clear down to 8 which by then the sub had stopped, the amp had shut off due to the low voltage and the cap soon did too.
I turned everything down to see if it would just charge back up....nothing. I got a voltmeter and started checking. First around the battery, before and after the fuse on the power wire, 12.8 volts (car turned off). So i then checked what it said at the cap and it said it was only getting 2.7 volts to it so i unhooked the wires from the cap thinking maybe somethin went wrong with it. I checked both wires before i even put them in the amp to make sure about both of them and it said 12.8 volts. But once i hooked them into the amp, it dropped to 2.7 volts on the voltmeter. I also did the same stuff with the car on and the volts just changed up to like 5 when they were in the amp. Can anyone help?
