jl 10W7 vs alpine type x
bebitte3o
I have the choice for this two sub at the same price, my amp is rated at 775rms at 2ohms (old kicker zr360), i want something loud with goood sq, i have 2 cube max for the box and sealed box alot more easy for my set up.
Thank's guys for your help.
nobody can give me info about type x,i don't find any info about x sub,what is the difference whith the swx-1042 and the newer 1043!!
Ok i read a lot of bad thing about the W7 but nothing on the x, the sub like small box is X or 7??
Thank' for your anser!
---------- Post added at 10:50 PM ---------- Previous post was at 10:49 PM ----------
I've owned more than a few of the old Kicker ZR series...they are beasts for sure but they tend to not like 2ohm mono. The only time I've run a 2ohm mono successfully on a ZR series was running an Audiomobile MASS at 2ohms on a ZR240...thing kept shutting down after maybe a 1/2 hour or so of running hot(and the ZR's do run hot). I eventually replaced the bottom plate of the amp with plexi and I mounted 2 small fans to the plexi(one pulling air in, the other blowing air out). After that she ran at 2ohm no problemo.
For that reason alone I would recommend the W7. It has a single 3ohm coil and Kicker suggested running the ZR's at 2.66ohms. Plus 750-800rms sounds about right for a 10W7 and might not be enough to get the full potential out of the SWX.
Also there were significant changes to the the second gen SWX. There is a review floating around somewhere on the interweb that really digs into the differences. I'm at work so I can't do too much googling around to find it. The highlights were a lighter/stiffer cone and they extended the pole piece to create a larger magnetic gap which kept the coil in the gap during the entire stroke, similar to an underhung design. There were a few other things as well but it's been a while since I read the article. Do some poking around and you'll find it.
Ok thank you guys, i will try the W7 but for the box what is best ported or sealed and i think one cube is to small for sealed, i have max two cube and the boxe will be made of fiber glass in a boat!
Hi guys After a lot of reading on this forum i decide to go different, i see ssa dcon 10d4 in sealed box but what is the ideal size box for this sub, a brand new sub cost a fraction of the price of the w7, what do you think about that,thank's
Thank's but after a lot a reading i go with other thing but i'm not sure, i see for ssa gcon or sa-10, dc lv2 i search the best sub for small sealed box or maybe ported but i can put only round port, i don't like porte noise it's wy i go sealed and it's for my boat.
I live in quebec (canada) and in quebec these brand don't exist and i never see or eared a lot of sub like ab fi tantric etc
Everybody run alpine jl rockford so i don't want that.
bebitte3o
bebitte3o
montreal
bebitte3o
