Jensen VM9022--Help
mrnbooc
I am installing this stereo hopefully tommorow. I have a couple of questions.
There is a brown wire that is used for the bluetooth,Where does it go?
What do I hook the parking brake wire to, and will it damage the unit if I don't hook it up?
The group of rca wires leading to the amp, If I am not going to use an amp yet do I just leave these wires alone?
Thanks for any and all help,suggestions, and helpful comments.
The brown "Bluetooth" wire connects to an optional Bluetooth control module that is usually for handsfree phone operation and a few other functions as well.
The parking brake wire is a safety feature for your DVD player. When connected correctly, it will allow the DVD player to operate when the parking brake is applied. In other words..... they dont want you watching movies while you drive. I always bypass this by running that wire straight to ground. If it is not grounded your DVD player will not play movies.
The RCA cables do not need to be connected because your particular HU has an internal amp.
mrnbooc
mrnbooc
Fayetteville,NC
mrnbooc
michigan born
    May 14, 2026
michigan born
    May 14, 2026
