jeep HU install help
i was thinking the same thing, as it would just pop off, but when i put the flathead under it it feels as its about to break..
but i think that is the only thing in my way.. is the plastic outer piece.
in my car i have the different style trim it may be more brittle idk, but its a pos bhah
Tug on the bottom and corners, make sure you have all the screws out, there on top in the middle and the bottom...then there should be 4 bolts that hold the stock unit in, it it like a 10mm or a 1/2 or 9/16 something idk....Jeeps **** I have had 3 //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
whoa there turbo
who just start tugging at the bottom of that plastic cover thing? and itl pop off then unscrew stuff??
or do i need to unscrew before i tug at it..
if so where the hell are the screws i cant find any..
i dont enjoy going outside when its 0º
did a jeep today.......no screws just give it a firm but gentle tug on the bottom and then the top, comes off easy and there will be 2 10mm bolts holding the deck in.probably the easiest cd player to remove out there.
yep i just put my hands under the bottom of it and pulled a bit and tyhe entire thing popped off.. ha
2 bolts rewire then wire RCA/remote/ipod get the tight fitting radio bak in and wala
flawless victory
▼)Ñ╩fZΣµ&
▼)Ñ╩fZΣµ&
reno
boogeyman
vegang
vegang
