MemphisCherokee
analrapist
fart box for memphis PRs
originally designed to use 4 5 inch ports at 16'' each
but after the realization that i cant get 5 inch pvc
went with 4 6 inch ports at 25'' each
though, after factoring outer diameter half way through the build, i decided to go with 3 6 inch ports at 18'' each
so, the box originally being a 3cuft common chamber, and most of it being built already, i switched to the 3 6"ers
by doing that it gave the shared chamber a good 7 inches leading to the common chamber bing about 3.75 (after displacement cuft instead of 3cuft
changing the tuning from 55 Hz to around 47-52 Hz
im not too disapointed with the turnout
its not meant to look good
its not meant to sound good
its meant to get ****ing loud for the dBDrag of sorts at highschool days at cordova on the 23rd
(well, not ****ING loud, but louder than my 37 hz Daily box
i made the collector plate of sorts after being inspired by the theory of ports that begin and terminate in flush pannels acting differently
and also inspiration from pete k.s crossover box
not really gonna know any numbers or results untill the 21st when im putting it in mah jeep
pics:
any feedback is welcome, positive or negative
pics:
