jbl gto 751 with dvc2 re sx18......?
sharkman
poor bass head
Ok i have a re sx 18 which is a dvc 2 ohm sub rated at 1k. So im thinking about getting a jbl gto 751 but its only stable down to 2 ohms. I was thinking about just using one coil. Would that work for me. I know the sub can handle more then 1k. My thing is when meade tested the gto500 it did its peak rating of 770. This amp peak rated at 1200. Will it do that? Will this amp do 1 ohm if i keep it cool.... thanks for the help
You need a 1 ohm stable amplifier to get the best power output for your money. Do not run that subwoofer with only 1 voice coil.
JBL is not going to warranty your amplifier if you run it at 1 ohm. I have done it with a 501EZ, but I do not recommend it.
Ok thanks. So what about running a amp on each coil not strapped. I was thinking of getting a the 501 and doing that. It would give me about 1200- 1800 rms total. People say dont do it cause its bad for the sub then i read its ok if they are tuned right.
It can be done, but this is not for the novice.
---------- Post added at 05:43 PM ---------- Previous post was at 05:43 PM ----------
sharkman
poor bass head
sharkman
oakland ca
sharkman
