Speaker (not sub) wire sizes? Before and after amp?
I'm going to be installing an amp for my component speakers, which are Alpine S-Type 6.75s, rated for 80w @ 4ohm. I'm unsure of the amp yet but it'll probably be ~75w per channel. I'm going to be using the stock head unit and speaker level inputs on the amp. The truck has 20ga wire stock.
What gauge wire should I use from HU to amp and from amp to speakers? Is there a chart or formula used to calculate this? Will there be a noticeable difference in the sound quality if I just go with the stock wires?
You shouldn't need speaker wire from the head unit to the amp unless you're using a factory head unit or one that has only a subwoofer output. If either is the case, 18-20 gauge wire is fine. Likewise with the wiring after the amp, although I prefer to use 16 gauge.
As for a sound quality difference, you'll only notice one if you've paid too much for your wire and need to justify it to yourself, lol.
boy&hisdogs
boy&hisdogs
California
bbeljefe
