JBL gti 12 inch please read
customlt1
Okay so about a month ago i got a jbl gti 12 inch strait from an authorized dealer....i put it in a 1.00 sealed box but it was slanted so it was way to small...the sub sounded like garbage in it..when you would turn it up decently it would make a weird popping sound almost like the sub was blown....so i then put the sub into a 1.25 slanted sealed box but still the same problem..so i took the sub back to the store and they got me a BRAND NEW one..went back into that 1.25 inch and still didn't sound right..so at this point i was thinking its the box...so i had my dad (hes a awesome box builder) build me to spec a 2.25 cubic foot ported box....EXACTLY to jbl specs for this sub....The sub is now in and i took it back to the store to get tuned.....Im not sure what its tuned too but i know the gains are very low....the sub bumps but not nearly as loud as it should....if i turn the gains up on the amp the sub gets MUCH louder but than again i hear that popping noise like the sub is blown..at this point i don't know what to do....the only reason i don't think its as loud as it should is bc i had an alpine x-type which is a VERY close comparison and i had that in a tiny 1.00 sealed box and that thing banged 10 times as loud as this jbl....well any help with this matter will be MUCH appreciated...thanks
i have a 99 jeep grand cherokee with a 12'' jbl gti in a 2.25 ported box 3/4 mdf....wiring is 4 guage and the headunit is a sony xav-7w flipout with a blankrupt dvd player....
I run 3 W10GTi's off of 2 BP1200.1's, and I must admit that I hear the noise you're talking about occasionally.
What I've come to learn, is that the subwoofer will be fine playing a slightly clipped signal. I mean SLIGHTLY. The BP1200 does in fact do around 1000 watts at 3 ohms. It's an underrated amplifier. Your best bet to avoid that noise is to turn the LPF to around 1/4 of the way up, and use very very little, if any bass boost.
By the way, what are the box dimensions and port measurements?
I have 2 gtis off of a bp 2200.1 in a dual vented enclosure and i have never had a problem with my subs sounding well.. My buddy has 1 in a 2.27 cube box in his new stratus on an older bp 1200.1 gettin sgnal from his avicN1 ( about 2volts from the preouts) and have never heard a problem from his either.. those are great subs so i hope that u get the problem fixed so u can enjoy them to the fullest.//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
Not necessarily. Mine is on and subs hit pretty good too....just ask the person that couldn't sit in my blzr no more than 4 sec....
coming from someone with (4) SE's....//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
just turn ur bass boost like off man..seriously...
okay heres some more info.....
my box design is
20'' Length
16'' width
14'' height
the port is
14'' deep
12'' height
my dad made the box so im not too knowledgable on how to explain it....hes an AWESOME carpenter this box looks awesome and he knows what hes doing with the info i gave him....the dimensions came from a jbl box designer at a local sterio shop...
on the amp there are three types of settings...Input(4v-250mv),Low pass Freq. 32hz-320hz)and bass boost (0-6db)
i just tried to tune it once again and the input is basically 1/2 dial around.....i dunno what you would call that as too how much i tured it up but its about 1/4 of what it could....the low pass is a hair turned....not much AT ALL...and the bass boost is completely off as you all told me too do.....
ok the sub hits but not nearly as hard as it should....the sub barely moves most of the time but once u turn the gains up a little it starts that popping..so basically im stuck with a sub that i can't get enough potential of what it should be doing....
any help would be highly appreciated....ya'll think this could be my HU wiring or something like that? im speechless
customlt1
customlt1
buffalo,ny
customlt1
