Jbl Bp150.1
well yea it will probably run even more than 200 but it's not a good idea to put the jbl down to 1 ohm. and to acheive 14.4 volts is not a cheap task you'd be wasting your time sione your running such a small amp
theres nothing wrong putting the JBL at 1 ohm. Theyr stabled at 1 ohm. i got mine at 1 ohm. u will probly get around 200 watts most likely over that since JBL amps are underrated
Specifications:
Output 4 Ohms: 75W x 1
Output 2 Ohms: 150W x 1
Signal to Noise (dBA): >100
Frequency Response (± 3dB): 20Hz - 500Hz
Total Harmonic Distortion: 0.1%
Input Sensitivity: 250mV - 4V
this is what i have found but o wow there isn't a rating for 1 ohm trust me it's not stable to 1 ohm yea you'll be able to do it but is it good for the amp?
Silica
Silica
Cambridge Ontario Canada Earth
Bavarian3
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
