JBL 1200 problem
Hey I have a JBL 1200 and when I installed it a red light came on instead of a green one. The manual says it is because of excess voltage B+ and to check for a faulty voltage regulator. Well is this the reason or not because I asked a few people and they said it could be several things i.e. speaker wires, RCA's, etc. But I disconnected everything except the power wires and it still did it. Any help?
Hmm, ive never had that problem with my 1200.1 . You have a good ground, correct? Thats probably the first thing i would check. After that can you get a friends amp to check with? If his amp is fine, i.e. doesnt go into protection, burst into flames, etc. that COULD mean that its your amp, and not any wires.
After that, ya got me.
blah blah blah blah.
I love the way JBL is attempting to play mechanic by blaming a voltage regulator for a poorly designed amp.
Likely the regulator is not the cause, as you would notice other things within your car not acting properly first.
A voltage regulator's job is to measure and meter the ammount of voltage that can safely pass from the alternator into the cars electronics.
Get ahold of a DVM - set it to 12 VDC, and take a voltage test at the battery and at the + terminal of the amplifier. - to ground and + to + in both cases.
Your reading should be almost the same at both test points, and if it is between 13.5 -14.7 volts at idle- everything is working correctly.
Assuming that your ground, remote, speaker, and RCA wires are all correct.
Amplifier is faulty if your charging system passes this test.
take it easy,
-zane
96blazekid
96blazekid
Fernandina Beach, Fl
Bavarian3
