jbl 1200.1 or lanzar 1200d?
  • Thread starter steadyru
  • Start date
  • Replies 5
  • Views 2K
  • 4
Definetly the JBL 1200.1!!!! That is such a simple question. Lanzar is not exactly crap but it is close to it unless it is the Opti line. The JBL amp is of high quality and more the money, one of the best.
also, the jbl 1200 will put out 1200watts rms into a 2ohm load, while the lanzar 1200 will only put that out if run at a 1 ohm load and the jbl is more efficient than the lanzar.
I'm on my 3rd 1200D, the 1st two were lemons. If you get a good one the 1200D is a fine sub amp, but if you don't want to take a chance on dealing with the headache of warranty work/exchanges, don't get the Lanzar.
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
973
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
5K
Guest
muffmanaj
    May 12, 2024
Brendon Jenness
    May 11, 2024
