Ive come to think that im over excurting said woofer.
Posted earlier about box issue. Thought my box was tuned too high. Turned out its jjust fine at 32 hz.
Now im trying to get that real good low end. this stuff right here.
Sa-12 on 1000rms.
Also i get that the song has some clipping above 0db in it. Thats easily remedied with keeping the volume down so its not clipping the amp.
Now...Should i just turn to full tilt and turn up my subsonic filter until i hear that click click of over excursion go away? Assuming thats how you get great low end and not destroy your woofer?
AS you can see that graph, that build up under 30hz is still significant and i get that im hitting mechanical limits because lack of dampening under tuning frequencies..
just curious as if this is how you remedy that?
Alright. Will someone inform me on mechanical limits and low frequencies? im all ears or give me a link to read. is it just not possible to be playing 28-30hz songs on a sa-12 with 1000rms with good volume?
i wanna learn but im totally lost as too what i need to be understanding here.
Damping factor is a number, derived from a calculation, given to an amp that tells you how well it can control the subwoofer. A higher number damping factor, means better sub control. Anything over 1000 is considered great. The old Kenwood 1023's had a damping factor greater than 1000, and it made 15" subs play as tight as 10's in anything but a completely junk enclosure.
You could take literally take a Pyramid sub in a ported box, on a 1023, and it would play as tight as any name brand in a sealed box ....
That is the quick version ...
Here you go, read this, and it should make it more clear ...
DAMPING FACTOR
Loudspeakers have a mind of their own. You send them
a signal and they add their own twist to it. They
keep on vibrating after the signal has stopped, due to
inertia. That's called "ringing" or "time smearing."
In other words, the speaker produces sound waves that are not part of the original signal.
Suppose the incoming signal is a "tight" kick drum with a short attack and decay in its signal envelope.
When the kick-drum signal stops, th
e speaker continues to vibrate. The
cone bounces back and forth in its
suspension. So that nice, snappy kick drum turns into a boomy throb.
Fortunately, a power amplifier can exert control over
the loudspeaker and prevent ringing. Damping is the
ability of a power amplifier to contro
l loudspeaker motion. It's
measured in Damping
Factor, which is load
impedance divided by amplifier ou
tput impedance. Let's explain.
If the speaker impedance is 8 ohms, and the amplifier
output impedance is 0.01 ohms, the damping factor
is 800. That's a simplication. Sinc
e the speaker impedance and amplifie
r output impedance vary with fre-
quency, so does the damping factor. Also, the impedance of the speaker cable affects damping. Thick
cables (with low AWG) allo
w more damping than thin cables with (high AWG).
The lower the amplifier's output impedance, the higher the damping factor, and the tighter the sound is. A
damping factor of 1000 or greater is consider
ed high. High damping factor equals tight bass.
How It Works
How does an amplifier control speaker motion? When the loudspeaker cone vibrates, it acts like a micro-
phone, generating a signal from its voice coil. This
signal generated by the speaker is called back EMF
(back Electro Motive Force). It travels through the
speaker cable back into the amplifier output, then
returns to the speaker. Since back EMF is in oppos
ite polarity with the speaker's motion, back EMF
impedes or damps the speaker's ringing.
The smaller the amp's output impedance, the greater is
the effect of back EMF on the speaker's motion.
An amplifier with low output impedance does not impede the back EMF, so the back EMF drives the loud-
speaker with a relatively strong si
gnal that works against the speaker's motion. When the speaker cone
moves out, the back EMF pulls the speaker in, and vice versa.
In short, the loudspeaker damps itself through the am
plifier output circuitry.
The lower the impedance of
that output circuitry, the more the back EMF can control the speaker's ringing.
To prove it to yourself, take a woofer that is not
connected to anything. Put your ear next to the cone and
tap on it. You might hear a low-pitched "bongggg" if
the speaker itself is poorly damped. Now short the
speaker terminals and tap again. You should hear a tighter thump.
I am not stating that this is your whole problem, but it seems that most modern amplifier companies are happy selling amps with only around a 200 df, which is not good ....
So it could be contributing to your issue ...
The lower the fq you are trying to reproduce, the more damping factor you need to properly control the sub ...
im not sure. Specs on ssa store for sa-12 says
1.75 ft^3 ported tuned to 30 Hz -- F3 of 26 Hz * Tune higher and use a smaller box for more SPL oriented setup (Use 1 - 1.5 cubes) * Enclosure can be as big as 2.25 ft^3 with lower power levels 1.00 ft^3 sealed -- F3 of 44 Hz * For SQ and space limited applications
box is 2.0- 2.2 cuft. so im thinking it might be too big for the amount of power im sending to it. 1000rms
The Camry
Hey, I Try.
The Camry
Western Oregon
Boominburban
