Loyd, Josh, read this straight from the RE site...
Our current top of the line series with the longest Xmag in
the world (verified by Dumax when it "broke" their test machine).
Complete motor linearity throughout the drivers entire
mechanical range. Resulting in incredible SQ and output.
10XXX Q1.2
Re 1.17 ohms per coil
Fs 35.2 Hz
Qms 5.73
Qes .45
Qts .41
Vas 14.5l
Sd 480 cm^2
Xmax 32mm one way
1600 Watts RMS
SQ: .5-.75 cuft sealed or 2 cuft tuned to 23Hz
SQL: 1.5 cuft tuned to 33Hz
SPL: 1.5+ cuft tuned for res freq
10XXX Q1.2
Fs 35.2 Hz
Qms 5.73
Qes .45
Qts .41
Vas 14.5l
Sd 480 cm^2
Xmax 32mm one way
1600 Watts RMS
