Issues getting my subs to produce
Riater
Hello, I have a couple questions and am wondering if anyone can give me a hand?
I have a 1000W Precision Power D1000/1 mono amp its 1 channel however has a setup that looks like this ( --REM++) for speaker connections so I suppose its good for 2 subs lol. I have 2 12'' Rockford Fosgate P3 subs in a ported box. I wired everything up amp turns on and I wired 1 speaker to the left most neg and left most pos and for the other speaker I did right most neg and right most pos. I for whatever reason seem to hardly getting any bass if I set the gain to high the subs hop but theres not really any BASS. the amp is set to LP and no matter what setting I switch to on the amp and or headunit everything sound like its **** lol. I know that was a mouthful and I am not the greatest at explaining but If someone can give me a hand to help me it would be greatly appreciated thanks.
take one of the sub connections and hook it up backwards and see what you get. my guess is the subs are currently connected out of phase.
Take the sub that is connected to the right - and right+ and switch them the - wire to the + spot and the + wire to the - spot. Only on the one sub don't move the other.
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
696
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
Are your tweeters amplified or powered by the radio or maybe factory amp? I'd check your wiring for sure, make sure 12v power and ground are...
Riater
Riater
Camp Pendleton, CA
Riater
