Is what I'm doing safe?
Here's the details:
99' Blazer
Pioneer X3700UI Head Unit
Stock 110 Amp Delco Alternator
Autocraft Silver Battery
Big 3 Upgrade done with 1/0 welding cable
2 Kicker L5 12's (06L5S12)
Hifonics BRZ 2400.1D Amplifier running 2400w @ .5 ohms
My Kickers are dual 2's, so I can only wire to 2 or .5 ohm. Meaning I can't get 2400 out of the amp (it's rating at 1 ohm). I decided to say f*** it and wire down to half ohm. Now I know efficiency goes right out the window with .5 ohm, but I wanna know if that's OK because I'm not demanding 3-4k out of it like most people would trying to double their power at .5 ohm. I'm just trying to get 2400 out of it, which is its max rating at 1 ohm, so, 2400 at .5 shouldn't be too bad should it?
I've been blasting em for a good hour now, and the amp gets a bit hot, but nothing extreme, no voice coil smell, no distortion. My voltage doesn't drop below 12v. Is this ok?
id probably say fuck it but dont clip it to death, measure your actual drop and rise with a clamp meter and go from there.
its worth the 15$ to buy one from harbor freight just to see where your actual rise is
I didn't realize they were that cheap! That will show me my real world RMS wattage that the subs are actually seeing too, right? And as a side note what can I get a good cheap oscope for? Nothing fancy, just me and my buddies tuning our systems.
Run the subs at double their rated power and the amp and half rated impedance, what could possibly go wrong?
Now that everyone has chimed in with their boogeyman advice you'll know that when you start breaking equipment it's from "clipping" or "not having enough electrical", not in fact from using your stuff way outside of it's design limits.
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Can anyone in here participate in a short interview I am doing for school about the installation of a Kenwood DMX4070S in my 2005 Ford Expedition...
There aren't many wires coming off the amp. There's: power in (12V Batt +, usually the big red one), power out (Ground, usually the big black...
AceAnderson
Michigan, USA
UsAmpsFreak
