Is what I'm doing safe?
Here's the details:
99' Blazer
Pioneer X3700UI Head Unit
Stock 110 Amp Delco Alternator
Autocraft Silver Battery
Big 3 Upgrade done with 1/0 welding cable
2 Kicker L5 12's (06L5S12)
Hifonics BRZ 2400.1D Amplifier running 2400w @ .5 ohms
My Kickers are dual 2's, so I can only wire to 2 or .5 ohm. Meaning I can't get 2400 out of the amp (it's rating at 1 ohm). I decided to say f*** it and wire down to half ohm. Now I know efficiency goes right out the window with .5 ohm, but I wanna know if that's OK because I'm not demanding 3-4k out of it like most people would trying to double their power at .5 ohm. I'm just trying to get 2400 out of it, which is its max rating at 1 ohm, so, 2400 at .5 shouldn't be too bad should it?
I've been blasting em for a good hour now, and the amp gets a bit hot, but nothing extreme, no voice coil smell, no distortion. My voltage doesn't drop below 12v. Is this ok?
its worth the 15$ to buy one from harbor freight just to see where your actual rise is
I didn't realize they were that cheap! That will show me my real world RMS wattage that the subs are actually seeing too, right? And as a side note what can I get a good cheap oscope for? Nothing fancy, just me and my buddies tuning our systems.
Run the subs at double their rated power and the amp and half rated impedance, what could possibly go wrong?
Now that everyone has chimed in with their boogeyman advice you'll know that when you start breaking equipment it's from "clipping" or "not having enough electrical", not in fact from using your stuff way outside of it's design limits.
If they die, they die. I'm going to upgrade to 2 good 18s when they do, so for now, **** it. I want it LOUD. Generally speaking, I'll smell it before it blows, right? Because they put off no coil smell whatsoever
If you can afford to blow up your equipment then why even ask? Just abuse it til it breaks and buy something else.
"Can" afford to is relative haha. I'd rather not blow them, cuz they'd put more cash in my pocket to upgrade, but realistically they are not actually seeing 3000 watts. Maybe close during a 50hz burp but on music it's less than half of that. They aren't even that much louder, probably 2-3dbs. I see people pushing triple-quadruple times rated power sometimes and they don't blow. A guy I saw a couple days ago had three 1k subs on bit over 5k. They were crying for dear mercy, and the smell was terrible, but they sat there and took it. If I don't smell em, it shouldn't be that big of a deal, right?
Your pushing lower end equipment past the threshold norm.
The brz is a very good amp, but its not the best to run at .5 ohm. Most bigger amps do fine dropping to 12v.
The brz may end up blowing on even 12.5v @ .5 ohm.
Keep it at 13v+ until you get a better alt and possibly an agm battery.
Upgrade your amp before the subs.
Sent from my Z970 using Tapatalk
AceAnderson
Michigan, USA
UsAmpsFreak
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
