Is this wired properly??
Twisted0811
CarAudio.com Newbie
My setup is Skar RP2000 1D pushing 2 Skar SVR12 D2's and this is how it is currently wired, when I removed my CVR's this is how they were wired so I copied it. However they do not sound right they have a rubber smell and are warm to the touch. My gain is only about a 3rd of the way up.
26406
This is how it is currently wired, but like I said it sounds way off. If I wire it to 1 ohm would that push my amp to .5 ohms I don't want to blow anything. Sorry just learning all this what would be the best way to wire it up
No I wouldn't do .5. Your problem must be something else. Can you take some pics?
My setup is Skar RP2000 1D pushing 2 Skar SVR12 D2's and this is how it is currently wired, when I removed my CVR's this is how they were wired so I copied it. However they do not sound right they have a rubber smell and are warm to the touch. My gain is only about a 3rd of the way up.View attachment 26406
This picture shows you only having one coil per sub wired to your amp.
correct that should be a 2 ohm load. I was afraid to run them parallel to 1 ohm in fear that I would put a .5 ohm load on my amp. Plus after watching this amp on the dyno it put out 1600 watts at 2 ohms and the subs are only 800 rms. This is the part I'm attempting to learn
Also that explains the smell and odd sound of the subs, I am looking at the way its wired and this amp makes 2200 rms at 1 ohm. So I am actually running these subs at 2200 watts to single voice coil. So thank you guys probably just saved me a pile of money.
And they will not perform as intended if half the coil isn't energized. There is virtually never a time to only run one coil of a multiple voice coil woofer.
Thanks I really appreciate all the feed back. I learned alot really quick with this thread. Yall are a good bunch of people and have a great deal of info on this site. Thanks again.
Twisted0811
CarAudio.com Newbie
Twisted0811
Florida
Twisted0811
Mike Mccabe
