Hintzyboy
Sparks mean its working!
I have an Orion XTR Pro 1000 and a Memphis ST3004 that I will soon be installing in my truck. Strangely, the Orion only takes 8 gauge wire, and the Memphis takes up to 4 gauge. I have a Stinger SWCKH44 that I would like to use, but it only allows for 8 gauge to be run from the distro block to the amps. I will be using the Memphis to power a 2-way active setup, so it will be producing 200-250 watts at most. I'm assuming that the Orion was made to put out full power with the 8 gauge wire. Do you guys think it will be enough to have 4 gauge run to the cap, then distro block, then 8 gauge to the amps, or do i need to look into more options?
