Is this to much power?????
Nothing fancy just a Lanzar 1500d:) .
First off that 1500 @ 1ohm is MAX rating. Not RMS. Id be surprised if you pulled anywhere near 1KWRMS.
SPECS
1 x 400 Watts RMS at 4 Ohms
1 x 800 Watts Max at 2 Ohms
1 x 1500 Watts Max at 1 Ohms
Mono Block Subwoofer Amplifier
1 Ohm Stereo Stable
MOSEFT Power Supply
PMW (pulse-Width-Modulation) System
Glass Epoxy PCB
Custom Terminal Block for Speaker Connection
Thermal, Overload & Short Protection
Variable Subsonic Filter (15Hz-50Hz, 24dB/Octave)
Variable Lowpass Filter (50Hz-250Hz, 24dB/Octave)
Remote Bass Control
Input Impedance: 10k Ohms
VU Meter
Thermometer
Heavy Duty Power Coated Heatsink
Frequency Response: 15 Hz-35 kHz
S/N Ratio: 90 dB
Dimensions: 10.95''W x 2.3''H x 15''L
got that right from Lanzar's site cuz I dont look at Lanzar so didnt no right off hand...
so no thats not too much power //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif keep gains down...tho..
On the inside I think the 1500D is a 1200D - that's about 400w a piece at full bore.
Be cautious with the gain settings and easy on the volume knob. You could roast them if you wanted to, but if you use a little common sense they should run fine.
Just so you know, in a parallel circuit, all loads (speakers) recieve the SAME voltage/wattage, so if an amp makes 500w rms into 2ohms, all speakers in that 2ohm loaded channel will recieve 500w. If they are in SERIES, the wattage is divided among the loads according to their resistance. To sum up, speakers in parallel do not "use up" the watts they need and pass the rest on, that is a series circuit. Thought I would clear that up.
I hooked it up, and it sounds great. I had an audiobahn amp running them before //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif , but as we all know Audiobahn isnt worth the crap:D . I fried the Audiobahn amp, and to de honest as cheap as Lanzar is they sound better with this amp. I am just tryind to get full sound in my work car:D . I know about audio equipment, my show car has all old skool US Amps and old skool Orion Subs:eek: //content.invisioncic.com/y282845/emoticons/bowdown.gif.b85b23b82970bd22fb6b549c3392f016.gif .
IMO Audiobahn>Lanzar
Just so you know, in a parallel circuit, all loads (speakers) recieve the SAME voltage/wattage, so if an amp makes 500w rms into 2ohms, all speakers in that 2ohm loaded channel will recieve 500w ... speakers in parallel do not "use up" the watts they need and pass the rest on, that is a series circuit. Thought I would clear that up.
Uh, no.
Current is = at all points in a series circuit. Voltage is = in parallel. In neither case is the power to all loads in the circuit equal to power at the source.
Following your logic - if you wired up 8 8 ohm subs to a 1000 watt 1 ohm amp each sub would see 1000w. If that were true every bass head out there would be doing it, not to mention - all the worlds energy problems would be erased.
revrider1
Hmmm...
revrider1
Down South~3rd Coast~TX
n2audio
vegang
vegang
