Is this right?
atldavek
GA
GM
P o w e r
Memory (+12v Constant) Orange
Ignition (+12v Switched) Yellow
Ground (-) Black
Illumination Gray
Dimmer Brown
Power Antenna Pink
S p e a k e r s
Right Front (+) Light Green
Right Front (-) Dark Green
Left Front (+) Tan
Left Front (-) Gray
Right Rear (+) Dark Blue
Right Rear (-) Light Blue
Left Rear (+) Brown
Left Rear (-) Yellow
I would like to know so I can install a line outup converter on a 1999 Bravada, and if these are the right colors I am just making sure that they will be the SAME colors when they get back toward the rear door speakers right?? I am thinking about tapping into them as they enter the door. Thanks a lot
As I am thinkig about this I realize that the Bravada's (and others like it) have 6 speakers so I don't know what the colors would be for this setup. I have looked around and have had no luck, thanks for any help. I would like to install tomorrow.
you sure it has 6 speakers? or does it have "a 6 speaker system" with th front speakers being a 2-way speaker? usually if stock speakers are 2 way speakers the factory counts then as 2 speakers and would be run off just the same front right/left +/-
-Mac
Thanks, I already checked it but now am just wondering about the 6-speaker setup.
Thought someone would know about the Blazer/Jimmy/Bravada setups...
I guess trial and error time..
Thanks!
im sure you just have a 4 channel power supply like normal and like you described earlier with just a set of 2-way speakers that the mfg just claims as 4 speakers plus the other 2 in the back to make their "6-speaker system"
atldavek
atldavek
GA
Mac11
