Is this ok?
Thats the half-asser's way of doing it... //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
Look around for other holes. I have mine going through the firewall in the same hole as my shifter cable. I had to cut the grommet a bit with a razor to get my 1/0 to fit through.
Not a good idea, over time you will pinch that wire causing the jacket to wear and eventually have bare wire showing. Bare Positive Wire + Metal = spark....byebye fuse (if you have one installed) if not, you then have fire
well i dont want to drill a hole through my car... its 2 gauge anyway so im sure itll be fine
So because its 2 gauge it cant be pinched and exposed?
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
you're a fvcking idiot.
That's not only dangerous but ghetto, lazy and half-assed.
Get your hands a little dirty and look under your dash for a rubber grommet leading into your engine bay. Or just drill a hole. It's not that hard.
W T F....
GREAT, another no advice takin' noob. You ask if it's okay, when you hear the answer that isn't what you were looking for, you leave it anway. Be sure to take pics when your car burns up.
Oh yeah, remember, we told you so.//content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif
Yeah I hate people who wire cars that way. You should never, EVER do that. Take it apart and start again by drilling a hole through your firewall and getting it done the right way.
Actually, from your other posts I have concluded you do not know what you are doing, and should take your car to a shop and ask them to properly install and set up your gear for you.
Popez
Popez
Minneapolis, MN
johnecon2001
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
