Is this how you wire a sub?
PWNED
I have a FI Q Dual 2.So does that mean its a 2ohm dvc?And has to be wired like this.I got the image off of the12volt.com
http://www.the12volt.com/caraudio/woofer_configurations.asp
I only see one set of inputs on that amp?
On the left side of the amp there are 4 places for wire.2 pos and 2 neg.Unless i am not speaking correctly.
thanks you answered my question iimmacomputer
2 outputs i think, aka 2 channels...
Please tell me your kidding. Both my MTX mono amps have two sets of inputs. From what I've read if you have say two dual 4 ohm drivers you can wire them down to 2 ohm and then hook one up to one set of input's on the amp and the other one up to other input and then the amp will see a 1 ohm load because how how those 2 sets of inputs are wired inside the amp. I'm still half asleep so this probably makes no sense at all but I tried.
Thats interesting..Ok so my situation it does not matter what set i use then
I have my positive going to one side and negative to the other side and it works fine, so no it don't matter which ones you put them on, as long as + is on + and - is on - lol.
Stop calling them inputs, theyre outputs.
PWNED
PWNED
Hooksett,NH
jkulysses
