is this going to hit hard?
ok cool response!! i have the amps i just blew some punch p1 15s with the amps and i got the volfenhags on fed ex. i am running two amps two 4g wires running to the battery is that ok or do i need a distribution block or something
Thats ok but not ideal
It might sound ok to you I guess. If you wanted to re do your setup you could get much better
why is it not ok to turn my gain all the way up on a 400 watt rms bridged amp pushing a 600 watt rms subwoofer it doesnt make sense plz explain in a kidna detailed fashion il understand
Your amp will clip and damage the subs. The gain is not a volume knob you have to be careful or all your stuff will be damaged. You can either get a DMM or you can just turn on a song you are familiar with, turn the volume about to about 3/4ths
Then turn the gain up till you hear distortion then turn them back down a little
I guess we all start with a basic system when you don't have the CA knowledge base under your belt...you might want to use these for a temporary setup until you dive into the forum and become hungry for a change......Darkhunter gave you excellent information..goodluck
dlow265
dlow265
oklahoma city
GAM3OVR
