is this amp anygood
got it it was 140 miles round trip
but i got the amp for free from some dude i never even met in my life he just said i could have it how werid he must of not knew how good it was cause this amp is awesome the sound is so good with it
he said he accidetly spray painted it but im going to get graffiti remover and try to fix it ill clean the whole think then try to use this car bleach on it to make it look new again
careful not to rub too hard cause you are basically using paint remover to get paint off of paint. you may **** up the finish on the amp even more. glad you got a nice piece of history right there. crossfire amps were pretty sweet back in the day.
here it is yea i sould buy itF/S: Crossfire Amp and Rockford Fosgate Amp Kit - ExplorerX Forums
im getting it for free the guy said just come and pick it up hes tired of it taking up space i hope it works
do u guys think its more powerful than a kicker zx460 and whats the high current thing mean is that somthing i have to worry about
the "high current thing" means it will run at super low ohms. and will put out WAAAAAAYYYYYYYYYY more than the rated 30 watts per channel. That my friend is what we call a cheater amp. used to be able to compete with it and say it was 60 watts but in reality its prolly around 600 - 800 watts.
yea what should i put it on high power or high current i guess ill use it for my highs unless is it good for subs ? i wonder how many watts it does
if running in stereo at 4 ohms (a pair of highs) you should keep it on high voltage. but if you plan on dropping ohms with multiple speakers or low ohms you need it on high current.
will prolly do around 700 watts at 0.5 ohms stereo or 1 ohm bridged. ( i think , dont quote me on it but i think its .5 ohms stable in stereo and 1 ohm stable bridged)
as far as being good for subs..........its not a 1000+ watt beast but it will assrape those kicker subs of yours.
some words came off
im waiting for the subtilis i hate the kickers
i have 2 pionner 6x9s and 2 sound stream comps i want to run on it they are like 80 watts a piece how should i set it up and they are wired to 4 ohms right now
markak134
Banned
markak134
pa
markak134
BP1Fanatic
BP1Fanatic
