is this a properly wired system??
traksta15
I love lamp.
ok i have a hifonics 1500D and a profile 200sx for my comps, so my question is, is this the right equipment i should use??
ok i have about 20ft. of 2 ga im ordering so thats the wire i'll be using......
coming off the battery to this fuse holder.....
http://www.cardomain.com/item/LITBANL2
going to this distroblock (nonfused, should it be fused?what size fuse should i use)
http://www.ikesound.com/product-product_id/527
then splitting off to a 4ga for the 1500d and 8ga for the 200sx.......
1. would i have any problems as far as blowing fuses, amps shutting down or anything???
2. is the 200amp fuse in the fuse holder by the battery too big?
3. too small??
thanks in advance, and all help is appreciated!!!!
the chart that i found only goes down to 50ft, am i looking at the right chart???what size fuse should i use for the 4ga and 8ga coming off the distro?so you're saying i should buy a fused distro block??any suggestions on fuse sizes for the distro block??
what about this distroblock?
http://www.cardomain.com/item/LITPD204
it holds up to a 60 amp fuse what should i use??thanks for the help!
that holder will hold up to 80A fuses. Use an 80A for the 4awg and a 60A for the 8awg
I know you're the wiring guy on this forum but it says it'll hold up to 60amps?im confused???also i looked on cardomain and couldn't find any 80 amp "tube shaped" fuses.......
traksta15
I love lamp.
traksta15
Mcalester, Ok
traksta15
michigan born
    May 14, 2026
michigan born
    May 14, 2026
