Is this a good Amp/Sub match up?
No, Pyle is bottom barrel poop.
If you need marine gear look at the following brands:
JL Audio
Wet Sounds
Polk (Though their marine subwoofers are not very good)
Kicker
Rockford Fosgate
Memphis
MTX
Kenwood (For micro amps and some head units)
Fusion
Digital Designs
Well I wasn't looking for marine gear. Trying to find an amp, 6.5 sub or Sub's, amp wiring kit and a LOC on a $200 budget. Going with 6.5 because of the limited space in my 07 tahoe. Plan is to build a down firing box for behind the 3rd row seats.
Let me take a step back and ask. Will an amp and subwoofer (X2) with the below specs work together?
Amp Specs
RMS Power Output: 300 Watts x 2 Channels @ 4 Ohm
Max Power Output: 600 Watts x 2 Channels @ 2 Ohm
Bridged Power: 1200 Watts x 1 Channel @ 4 Ohm
Full Range, Class A/B
Low Pass Filter: 45 Hz to 90 Hz
High-Pass Filter: 50 Hz to 500 Hz
Bass Boost: Variable 0 to 18 dB
Wired remote bass level control
RCA inputs: 2 CH
High Level Inputs
Input Sensitivity Switch
2/1 Channel operation
Thermal, Overload, and Short circuit protection circuitry
Signal-To-Noise Ratio: 84 dB
Channel Separation: 90 dB
Frequency response: 20-20000 Hz
Subwoofer Specs
Black Steel Basket
Non-Press Paper Cone
Specially Treated Foam Surround
1.5'' 4 Layer Dual Voice Coil
Dual 4 Ohm Impedance
30 OZ Magnet
300 Watts RMS / 600 Watts Max Power
SPL: 89 dB
Amp Specs
RCA inputs: 2 CH
High Level Inputs
Subwoofer Specs
Black Steel Basket
30 OZ Magnet
SPL: 89 dB
don't get sub with less than 2" coil and 60oz magnet everything smaller than that tends to blow very easy..
Amp Specs
RCA inputs: 2 CH
High Level Inputs
Subwoofer Specs
Black Steel Basket
30 OZ Magnet
SPL: 89 dB
Did you really just post the specs of the Pyle's expecting a different answer? Really.....
The problem with Pyle is they don't meet their own specs. So I will say it again. Pyle is trash, if you want to buy it, please buy it but don't come on here later and ask why it doesn't sound as good as you expected. Also your stating you want it because you don't have room, did you look into the enclosure size it wants? It's .5 Cu ft. EXACT SAME requirement as a shallow Pioneer 12"
If you want BETTER, and keep you budget under $200. Get a Pioneer or Dayton Shallow Sub (You can get the Pioneer in as small as an 8), And you can get the Sub and enclosure for under $100. Then find a 400-500W RMS Amp, for under $100 all day, plus you can get a 8 gauge OFC kit for sub $30.
DONE.
That's not true at all.....there you go again misleading info.
most i had blew thats y i never look at anything with less than 2" and can't believe u recommending cheaper sub after yelling about my 2.5"vc sub w/ dual spiders, 120oz mag, 600rms pioneer for months.. but now pos 1.5 coil is ok..
Then you did something wrong. Please show me where I recommended a cheaper sub.
https://audiolegion.com/collections/monoblock-amplifiers/products/al1200-1d-1200-1d-monoblock-car-amplifier
528
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
651
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
649
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
kredfearn
kredfearn
Gardner, Ks
BOOMINGRANDPA
    May 16, 2024
    May 16, 2024
