is this a bad combination...
  • 5
dvrmstrng
DE
well right now i have what youd call i guess an amateur SQ front stage...7" mids, some tweets running active and a nice head unit....my problem is my two ID8's in my side panel sub box isnt cutting it bass output wise....right now i have 600 watts @ 1 ohm to work with...
i was wondering if going with a SPL type woofer in the trunk off of the 600 watts would ruin the point of my "SQ-ish" front stage....
i thought about it...i just hope that something off of 600 watts that is in the trunk and theres a gas tank in between will get loud enough
The trunk is pretty tricky in the GTOs.
I am building a SQ GTO right now and am doing 2 12" subs in the rear seat area run off of 1500w each. We can always turn them down if we want to balance it out better. But we were going to put the subs in the trunk, we even cut out the entire rear deck area to vent it but found it still didnt perform the way that we wanted.
thats exactly what i dont want....and no i didnt glass them its an MDF box but the two 8's arent cutting it...i just wish i could get a SI BM
My 2 - 15" wedge box is around 5 cubes net with 80 square inches of port. My 4 - 8" wedge box is 3.69 cubes net with 43¾" square inches of port.
338
Bonjour et bienvenue à mon ami d'outre-Atlantique! Need a lot more info on what the goal is and what you are working with. What car? Did it come...
Hello back, For those who are also looking for a problem of sh*t bass, after such a long time of fighting, I come to a conclusion that the...
17
4K
"large crimping tool" hammer or hydraulic? Seat bracket bolts aren't good. The seat brackets are usually completely painted and so are the...
All that carpet will have to be ripped out and replaced. There is no other way around it to get it done properly. Seal both sides of the...
17
dvrmstrng
dvrmstrng
DE
Horsemanwill
Brendon Jenness
    May 8, 2024
    May 8, 2024
