i always wanted to know to....i heard somethin about gettin ur Amp clamped.
No. The "efficiency" takes place inside the amp. Input = Output so power in is equal to power out minus heat generated (in simple terms). The ratio of output power to input power is the efficiency. So if you're measuring the power leaving the amp (speaker leads) it will be accurate using the mentioned formula.wouldnt you take.. amp efficiency*volts you're running*amps(fuses)
ie. .86*14.25*120=watts
use a dmm, power = voltage squared divided by impedance. Should get you close, if you disconnect your speaker leads so impedance rise isn't a factor.
I think the objective is to do a max power test on the amp, not set the gain for X power into Y impedance which is what it sounds like you're describing -- unless I'm just not following.This is what you should do.
The problem with a clamp meter and a DMM measuring voltage and current through the speaker lead is you still don't know (at least not with any degree of accuracy) what ACTUAL impedance the load is presenting the amp OR at what point the amp is at full power before clipping.Clamp meter + DMM, measure amps with clamp, volts with dmm. 60 hz tone. multiply the two readings.
I think... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
