Is my box fine or should i add polyfill
kurtfromct
CT
i bought 2 JL 10W0v2 subs, which call for 0.65 cubic feet of volume each. the box i bought says it has 0.64 cubic feet for each sub. would adding polyfill be beneficial or a waste? i did some reading and found polyfill is used to simulate having a larger enclosure then you really have (i think).
See if you like it first. If you feel like you're lacking low-end, add some polyfill to see if that helps.
alright. just curious, do many people with sealed enclosures use polyfill? it doesnt seem like something i hear talked about much.
Normally people use it if they're forced to build a box smaller than what is recommended in order to compensate for the lower than normal box volume. It's not terribly common, especially on a forum like this where most everyone is running ported boxes.
makes sense. thanks
kurtfromct
kurtfromct
CT
iamamp3pimp
