is my amp performing up to its potential?
Ill tell you what. your nuts if your looking for punch in the face at 1000 watts in a prefab. Shoulda gone aq for 1000 dollars less
ok but ill have you know that my JL is 1000w peak rms handling. so why wont it hit as hard as possible with this amp? not many amps can do 1000w rms at 3 ohms or am i wrong? WILL I SEE an improvement from any upgrades IS MY QUESTION?
Your wrong //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif lots of amps can do more then 1000rms@3ohms
and yes your voltage drops should not be as sever...Thats about it
If your lights are dimming, you have voltage issues. Do the big 3 and/or buy a nice dry cell battery. It might not make your sub louder, but it'll more than likely take care of the dimming issue...
EDIT: chaunb beat me to it. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
what question did you ask? if its going in my m3...not a chance. it is my 2000 jeep gc.
Ok, so you say it's loud but doesnt rip your face off?
1) What kind of box and where did you get it?
2) give it some break in time, it is still very stiff and will get louder/lower over time.
Its ok I still luvs you //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
with that amp, cause its good quality jl, you will get your 1k watts rms oiut of it down to 11 volts. Meaning if you dont ever dip below 11 volts, which i hope you wouldn't ever, you will always see the 1000 watts out of that amp. So the only thing that would make it louder is the box it is in.
I will only accept the luv if it's from that gorgeous specimen in your avatar...//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
so then what would you say would be the best box for a 13w7?
It would have to be homemade, or custom built, People here build them, Some would even hook you up with ideal dimensions. If your sub is in a store bought box now and are pretty happy with it. You will be amazed in a custom box for your sub.
fasteddie03M3
fasteddie03M3
Syracuse, NY
jon_k
