Is my alternator enough?
alright so first off im currently running a single powerbass 10" with about 300 watts rms going to it out of a 900w pioneer amp... i want to upgrade my system and have just bought all the stuff to do the big 3 (not installed yet) and was looking at putting 2 10s (thinking the soundqubed hds310s) with a 2000-3000 watt amp to power them. i drive a rather small car (06 miata) and it only has a 100 amp alternator and i was wondering if this would be enough or if i would need to upgrade... the biggest alternator ive found for my car is a 190 amp unit but it is slightly expensive and if i could avoid it id like to :p
Your alt isn't big enough for more than 1500-2000 rms at most. You'll need the bigger alt to support 3000 rms
will the 190 amps do it? or should i just realize that im shooting to high?
---------- Post added at 09:50 PM ---------- Previous post was at 09:49 PM ----------
mylows do u have a cost for a kia 2014 forte alt and do u know how much stock is on that, thank u
that alternator is a 110 amp alternator stock
thank u, is there a good site to check out stock alt info
what brand is the 190 amp alt?
the 190 amp is by maniac electric motors though I did just find a 180 amp by quality power. Those are the only 2 direct replacements I've seen worth more than 125 or so amps the quality power alternator runs $120ish more than the maniac with less amperage though...
Don't bother with maniac electric motors OP. I ordered a 190amp "High output" alt from them and I highly doubt it's putting out any more amps than the stock alt I had prior to that one. General rule of thumb... You pay for what you get. Usually. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
jc4def
jc4def
Hayes, Va
Jeffdachef
