is it worth it to have brakes!?
bannock. Did you have some on help you bleed the brakes. Like they pump the peddel hold and you open the bleeder up see fluid come out close line. Start at the RR tire work around Like that. Sounds like you have air in the system. You could give bleeding the master cylinder a try too.
x2 but not nessicarly the RR. Witch ever is furthest from the master cylinder really.
exactly, from the furthest to the closest. Usually this is the RR but not always. I would check for any open lines though. One other thing is if you let an air bubble get in it during the bleeding process very possible if you were doing it alone that could be your cause.
bannock
bannock
winnipeg,mb
mapolley07
