is it me or is there something wrong
on winISD is called end correction. it has 3 difrent settings that you can use that will effect the length of the port.
but the change will only be minor like you have seen. if your port is runing along the wall. then it will make the port shorter because the air mass will still think is inside the port for a short distance and winisd takes that into consideration automaticaly.
NightHawkFG
Don't Hate
NightHawkFG
Houston Tx
NightHawkFG
