Is it dangerous to run 800W speakers without amps
the Pioneer head unit is rated 50Wx4 but that is a MAX power rating, and only attainable for a second with a lot of distortion.
Even the 22W RMS rating is at too high of a distortion level to be listenable.
In reality, you get about 12Wx4 out of a head unit with audible distortion. It's enough to be "loud" but it doesn't sound very good.
a good amp rated 35W RMS x4 @ 4 ohms and 0.05% THD would sound amazing in comparison, and play much louder while sounding good.
when discussing power you must discuss distortion. the internal amp in a head unit is an IC amp, no bigger than a credit card. compare that to an amp the size of a text book and you can figure out that one will be MUCH better than other.
when you evaluate amplifier output you need to consider the following:
* RMS power rating
* Impedance load
* THD at power rating and impedance load
* duration of power test (one second vs one hour)
* damping factor
* amplifier Class (A/B, D, T, etc.)
it's important to set the record straight so n00bs who find this while searching don't get the wrong idea.
and it's pointless to flame someone for asking a question. people who flame n00bs are usually idiots who don't know the right answer, so they bash someone else.
if you have useful and educational information to provide, do so. if all you can do is bash people for asking questions you should STFU (not directed at you on1wheel1, just sayin').
point is, people are asking questions which is better than just doing stupid stuff. nothing wrong with asking a question. everyone was a n00b once.
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
I am out of the car audio world the more my ears age. However, I am very much still a hobbyist in the electrical field. With much of my current...
15
Running wattage below RMS won't hurt anything. What the speakers get is the same thing as running an amp with higher wattage and then turning the...
14
rocky12345
rocky12345
ja
keep_hope_alive
audiobaun
    May 19, 2024
    May 19, 2024
