OK so I have a mj-18 SVC4ohm I know that a 2chanal amp (class a/b ) is a lot cheaper than a 1chanal (D class ) amp but wont the class a/b amp be a LOT harder on the electrical than the D class amp right? if so by how much?..I would like a 500/600Wrms amp but I have a 75amp alternator will a 500/600Wrms class a/b amp be OK on my electrical?........
think-you
As was pointed out earlier; Most class A/B amps will be operating at very low efficiency with musical content as they are typically in the 30% range @ 1/3 power wereas class D's are typically 60% or better throughout their entire range of power.
So, lets take a few examples pulling #'s out of the air.
We'll say both are 600w amps.
1/3 power of a 600w amp is 200w.
Assuming the class A/B is 33% efficient here, with a 12V power source it's current draw would be 50A
The class D, using a figure of 70% efficiency, with the same power source it's current draw would be 23A.
So @ 1/3 power in this hypothetical example the difference in current draw would be 27A
At full power class A/B's typically increase to the 50-70% range while a class D typically stays around the 60%+ range.
So at full power, with 55% efficiency (using figures on the low side intentionally) the class A/B would draw 91A.
The class D with an efficiency of 65% @ full power would draw 77A
Difference here of 14A @ full power (barely ever realized with musical content)
So there is a hypothetical scenario to give you an idea of what the differences in actual current draw would be. Again, since it was based off of assumptions in reality the differences could be slightly more or slightly less, but it should give you a general idea.
