What you're describing does not sound like an issue with a class D vs an AB.
Sounds like the 1200D has a much higher damping factor, which is what sustains the note and draws it out insted of just punching and going off.
There are AB class amps with INSANE damping factors... so, that arguement is null and void.
No, you have it backwards. Higher damping factor is good, lower is bad.. hence why class D amps arent used as full range amps, but subwoofer duty only where complete accuracy is not an issue.
Switching amplifiers like Class D amplifiers generally have a lower DF than their Class A/B counterparts because the output of the amplifier has to pass through an inductor. Since the inductor is wound with copper wire which has resistance (albeit a very low resistance), the DF is reduced.
Directed '06 model 1200D:
---Type Class D Mono
---Maximum Power 1200 Watts
---CEA S/N Ratio
(referenced at 1 watt/4 ohm) 60dB
---CEA Additional Power
(power into X ohm, all channels driven, 14.4V supply 1% THD+N) 600W x 1 @ 1 ohm
---Frequency Response 20 - 250Hz
---Damping Factor >50
---Crossover Type Variable 12dB low-pass
Alpine MRV-1507, '01 model
---Power Output: RMS Continuous Power (at 14.4V, 20 Hz to 20
kHz)
MRV-1507
Per channel into 4 ohms ......................... 225W, 0.08% THD
Per channel into 2 ohms .......................... 450W, 0.3% THD
Bridged into 4 ohms ................................ 900W, 0.3% THD
Frequency Response ................... 10 Hz to 50 kHz (+0, –1 dB)
---Signal-to-Noise Ratio
(referenced to rated power) ........................................ 105 dBA
---Damping factor
MRV-1507/MRV-757 ................................ Greater than 500
So, Directed 1200--- >50df
and, Alpine 1507--- >500df.
Yes, my amp has an insane df rating.
