Is A Signal Processor Advantageous When Used With My Pioneer DEH-80PRS
Madness0528
My head unit already kicks *** as it is and has various kick *** specs such as 3-Way Active Crossover Network, 24-bit D/A Converters, Auto EQ, and Auto Time Alignment.
But if a signal processor is a good idea which models would be recommended. I'd like to keep the price under $300 if possible.
Bear with me if this is a stupid question. I'm getting old and have forgotten so much and don't have the time to keep current.
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
u may be referring to the yellow wire and red wire. But there's a voltage drop just at the on position. So no signals come in via antenna. Or...
Yeah but accubass only restores the bass roll off. It doesn't take an incomplete signal range and make it a full range signal.
13
If this amplifier is an aftermarket unit, it should have RCA Output. If it is not, then connect to the rear amplified speakers. The sub amplier...
Madness0528
Madness0528
United States
dailyrider123
    May 19, 2024
    May 18, 2024
