is 900 rms @2 ohms to little for 2 type r's?
You should get two different amps to start off with or an amp that can be ran @ 2ohms. Your current setup will only allow you to run it @ 2ohms or @0.5ohms. Only a handful of amps are stable @ .5ohm.
900rms would be fine though.
I think he said his amp can be run at 2 ohms. He's fine with 1 amp that can push 900 watts @ 2 ohms. He just needs to wire each sub in series for a 4-ohm load, and both subs need to be wired to the amp in parallel to pull down the ohms to 2. It'll work just fine.
I would be looking for a bigger amp if I were you. The R's are very power hungry and if you look around, most are feeding a single 12" 700-1,000 RMS each. 900 RMS for 2 should move them decently but I think you'll be wanting to upgrade pretty quickly.
they are runnin @ 2 ohms now but in a really small ported enclosure. will the right enclosure make a big difference in spl?
heres the spec's of the box they are in now!
Dual 12" Ported MDF Enclosure
2 Seperated chambers
Airspace: 1.12 cu. ft. per chamber/li>
Port Dimensions: 1" W x 11-3/4" H x 8-3/4" D
Cutout Diameter: 11-3/4"
Dimensions: 28-1/8" L x 14-1/4" W x 13-1/4" H
open that son of a ***** up to at least 2ft^3 per chamber with 25in^2 per port opening if you do dual openings, otherwise 50in^2 for one port...Your choking those things in that tiny box. And yes, it'll make a huge difference on SPL in the proper enclosure.
bang hard
bang hard
chi town
j3bus2k3
