I've kinda always pondered that. I know sony's are pretty much the low end of low but I'd still be interested in knowing if the ones that died at rated rms wattages also had all the other settings such as gain and whatnot set right to keep them from distorting to pieces. :/
I'm still debating hooking this amp up to them or just leaving them run off the head unit and selling the amp for a mono block and only amping the sub... I'm getting pretty mixed opinions here.
Common practice in many car audio shops and chain stores is to try to get people focused on closely matching wattage ratings on amps and speakers. This is very likely because staff is afraid that if they enlighten the masses about the benefits of lots of overhead and explain how meaningless rms ratings can be if you know what you're doing, there will be less room for error when people go home and start doing silly things with the controls. As a result, they'll have more blown speakers coming back.
Understand, if a given amp is rated for 75 watts rms it does not mean that it is putting 75 watts to a speaker 100% of the time. These amps are usually rated with input voltages that most stock electrical systems won't deliver,
using test tones that don't represent what the amp will do when it's playing music. Depending on gain, the music, and the volume level, at times, your amp may be delivering as few as 1-15 watts or as much as 50-60. It will reach 75 watts if you have an upgraded electrical system capable of pushing it to its full capabilities, the volume dial is at the maximum undistorted level, and you've reached a musical peak that matches the volume level of an unattenuated test tone. About how often do do you think all of these stars will align while you're driving around listening to your system?
I'll tell you: All the time if you set the gain to high, regularly go above that with the volume dial, and boost signal, which alot of people do. This is why most shops will strongly discourage a package deal involving an amp making too much more rms wattage than the speaker is rated for and will incorrectly tell you this is always a no-no. This misinformation gets around, and now everybody thinks it's better to match watts exactly down to a fraction of a watt then turn gains up and boost signal when it's not loud enough, rather than to safely exceed the speaker's ratings and give yourself more loudness without sacrificing clear volume.
You may never see all of that amp's power if you set your gains properly and avoid over-boosting at the head unit, which is why it's not uncommon for people on here to run 2-3 times a speaker's rms rating with no problems. Meanwhile many who match rms ratings end up disappointed with their system's loudness.
It is possible that your amp could be rated at 75 watts rms but never, ever actually deliver that to a speaker for as long as you run it. Even if your amp can do an honest 75 watts rms and your speaker is rated for 40, most of the time that speaker may see an average wattage that doesn't exceed its rating by much. If it does exceed it, it probably only does for a brief instant before going back down because as the loudness of the music changes the wattage being delivered changes. Where you get into trouble is when a combination of bad adjustments causes you to deliver more 'dirty' power to the speaker than it's rms rating for extended amounts of time. Even a little bit of a clipped signal is extremely powerful and can put you way above the speaker's rating more quickly than running clean power at or above the speaker's rating at moderate volumes.
Dial back the gain if you hear something wrong and make further adjustments at the volume dial as needed when playing a louder recording and you will be fine. You may also have to run your high pass filter a bit higher than the standard 75-80 hertz.
