Irritating Problem.
  • 4
Tone415
A.K.A FrisnoG
Im going to give as much background info as possible.
Car is a 96 Acura RL3.5
I have the stock stereo. Using the stock front stage for now. I have a LOC comming from what was the rear 6x9 wires to a mono amp @ 2 ohms. one sub.
I wanted to add 3 way 6x9's to the rear to help with the mids/highs. the stock 6x9's only played bass. so i connected the 3-way 6x9's to a 2 ch amp. One speaker per channel @ 4 ohms each channel.
PROBLEM
6x9's ONLY play bass. No matter what settings i use on the amp, the amp will not play any kind of highs. ONLY bass. So i put the same amp and 6x9s to a friends car.. works fine. WHAT IS THE PROBLEM!?
Your stock radio has outdone you by providing rear fill correctly ROFL. Just quit being a cheap *** and grab a new head unit. Or your amp is not set to full pass
cheap *** is not the problem. there is no "dash kit" for this car and i am unable to make one atm.
---------- Post added at 10:04 AM ---------- Previous post was at 10:03 AM ----------
It sounds like the stock HU outputs a signal that filters out the highs in the rear channels.
Run your LOC from the front speakers
Thanks.. Thats what i didnt want to do because i dont really have the time to, but i guess ill have to make time to do it.
Thank you for explaining it in layman's terms. I understand now.
35
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
668
https://www.caraudio.com/threads/all-bnib-focal-fdp-4-600-ds18-exl-p2500-1-sundown-audio-sfb-1000-4d-350x4-4ohms.614462/ :)
18
800
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
556
Tone415
A.K.A FrisnoG
Tone415
San Francisco, CA
Tone415
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
