inverting multiple subs common chamber
dmz2711
FL
All right, i was wondering how to wire multiple subs 2 inverted and 2 regular subs in a common enclosure, without any of them canceling eachother out... I drew a quick diagram below on how i think it should be done, if anyone knows if this is correct, it would be great!!! //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
won't that just put the subs in series wiring???
In series but since some are inverted they have to, well at least this is understandable to most, they have to work in reverse. Since normally a sub is wired pos to pos and neg to neg a sub that has the cone firing into the box has to be wired pos to neg and neg to pos so that the two subwoofers do not cancel each other out.
so would the diagram be right then??? I mean, i am wiring the normal sub (positive), to the inverted sub (negative), correct????
what is the advantage of having inverted subs?? is it batter SQ? or just looks?
This might sound like a dumb Q, but im new to car audio
Thx alot, im welling to learn, its going to be my first system, and everybody has been very helpfull.
BTW, whats a inverted subs?
its a sub with the rear out of the box. I don't think any difference in sq, just more sub box volume...
so is the diagram correct???????????
high impedance
dmz2711
dmz2711
FL
Remotia
