dannyz122001
does inverting subs have an effect on SQ or SPL? i have no clue so i was hoping someone could inform me. thanks
If you have multiple subs, or multiple coils wired in series or parallel, its generally easiest just to reverse the speaker wires at the amplifier. Make sure your amp, h/u or any pre-amp you may be running does not already have a phase shift adjustment option you could use.ok, one more question. since I am a noob, i need extra clarification. in order to reverse the polarity on a 4ohm DVC sub to produce a 2ohm load, i need to wire it in parallel. since i am reversing it, do i connect the neg from the amp to the pos on the sub and vice versa? and then just connect the neg from the 1st coil to the neg on the 2nd coil and the pos from the 1st coil to the pos on the 2nd coil?
