internal bracin
  • 2
Matador
-= StillBumping =-
2,050
Ca
i was designing my box for 2 12'' edks n ti came up to be
W1 = 8'' W2=11'' L=31.5'' H=15.5''
for a totla of 1.0634 cu feet before displacement, but i was reading n i would most likely need bracing inside. i'll be using separate chambers.
would it help the "bracin" if i use 2 MDF pieces for the middle separator instead of just one? and how would you brace the inside? by connecting the 2 panels that connect (like in an L shaped side, u pur one like P, think of the L but with the block).
n one last question, for more strength,
for the BACK PANEL of the box, let's say u put it laying on the ground, so for the 2 widths of the box, do u nail them on top of the back portion panel like
or on the outer you nail the back portion onto the edges? like
|__|
remember, this is for strength purposes that i am asking. thanks a lot
dependant on the power your running that divider may be enough to stiften it suficiently....i think your going to be alright, genrally i always bace, but most the boxes i build are considerably bigger than that.
i will only be sending 400rms to each sub.
can anyone answer this one tho
think that you put the box facing up on the floor (sub openings on top) looking towards
the back of the box thru the openings..
|__|
n with only this much power, do you think is needed to double panel the middle divider? put 2 panels instead of just one (3/4'' each panel)
|__|
it doesn't matter which way they go, both are acceptable, i hope your not nailing unless your usuing THIN brads to hold the glue? you should be fine with singl 3/4" mdf all around.
Ok thanks, i suspect that this one i uave may be faulty. I will purchase another one for the sake of it and see, thanks
483
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
871
Just the amplifiers use batteries to power it up. The HU are powered up by the car battery supplying 12 volts. The wiring harness...
Not sure what your options are for buying there then. Certainly NOT what we have here and I'd imagine between shipping at VAT tax you'd get...
Matador
-= StillBumping =-
Matador
Ca
evo2k3
    May 18, 2024
    May 16, 2024
