Intermittent Stereo low volume/distortion
  • 4
JSully
To start off i have an 02 Ford Escape, current setup is a Pioneer Avh-201ex head unit and Rockford Fosgate P1683 speakers, soon to be adding a powered subwoofer. I'm having this problem where every once in awhile the stereo volume will have to be raised more than normal to match the volume i would normally listen to it at. For example, i normally listen around 14-15 volume and it will sound clean and have good bass, but when this problem happens, to match the same volume I'd have to raise it to probably around 20-22 and overall it sounds much worse and distorts the sound really bad, with almost no bass. In the past i fixed the problem by turning off the car and turning it on again, but i tried that a couple times tonight when the problem started and it didn't fix it. Any help would be appreciated, overall I'm pretty new to car audio.
either a loose connection or a bad head unit. i had a avh-x4500bt crap out on me and it was only a few years old also not entirely pleased with the avh-2300nex i currently have. this camel guy might be switching over to marlboro for my next purchase
or could be your music source, ex. going from a 128 kbps to 192+....(sorry if your smart enough to know the difference, alot of tards around here lately)....does it do it on same song/album?.....
Checked all connections, everything was still good. The problem hasn't came back since i originally posted, and no it's definitely not a certain song/album. Last time it happened it was like that all day and partly into the next morning and then went back to normal after i restarted the car. Maybe it's something to do with the cold messing with the head unit on certain days or something 🤷‍♂️ I honestly have no idea
did you make the proper sacrifices to the car audio gods? they require a herring and a shrubbery!!
Have you checked if the RCA themselves plugged into the amp are showing voltage now with the radio off or volume all the way down? Check and make...
561
With the new info that factory amp is still connected, Coolhand20th's original assesment may be right. Radio may be causing the noise. I would...
14
Hello, I have a Peugeot 207 SE 2007 and would like to upgrade its existing car stereo. It’s a single cd fm/am radio and I would like to get...
JSully
JSully
youdoofus
    Apr 28, 2024
    Apr 28, 2024
