Interesting computer problem
Supergumby5000
Project: F350 begins...
Okay, yesterday i let my roommate use my laptop
no big deal, he's used it before.
however, this time, he deleted my recycle bin.
again, i thought, no big deal. i only had a shortcut link to my recycle bin on the desktop. So, i do a search for my recycle bin.
"no results"
any ideas? This is on vista. I can delete stuff and its sent to the recycle bin, but i cannot find it lol.
Here is the link to make "Delete Recycle Bin" option not work.... I used it when I was still running Vista.
Remove Delete from the Recycle Bin Properties
Here is an ideal solution for when you have an incompetent user, who keep on deleting their Recycle Bin, and then pesters you to cure their clumsiness. My mission is to edit the registry and re-program the Recycle Bin's short cut menu.
Registry Tweak - Remove Delete from the Recycle Bin Properties1) Launch regedit (See more details on starting regedit)
2) In Regedit, navigate to the following key:
HKCR\CLSID\{645FF040-5081-101B-9F08-00AA002F954E}
3) To create a new registry Key called 'Shell', click on the Edit Menu, New, select: Key and name it 'Shell'. You should now have:
HKCR\CLSID\{645FF040-5081-101B-9F08-00AA002F954E}\Shell
3) Under Shell create a new (Sub) Key called 'Delete'. Click on the Edit Menu, New, select: Key. You should now have:
HKCR\CLSID\{645FF040-5081-101B-9F08-00AA002F954E}\Shell\Delete
4) Edit the 'Default' REG_SZ, as this is just a string value for display you could set to anything you like, for example 'YourName's Indestructible Bin'.
Conclusion
What you have done is replace a working function called 'Delete', with a cosmetic label called Xyz's Indestructible Bin. The sole purpose is to prevent users pressing 'Delete' and thus losing their Recycle Bin.
Supergumby5000
Supergumby5000
Pullman, WA
Jmac
vegang
vegang
