Installed Kickdown - Stereo Won't Power On
It doesn't turn on at all. Maybe its possible a wire came out of the plug. Also, the keyless entry stopped working unless the key was in the ignition, so that was messed up also after I installed the kickdown
yea sounds like a wiring issue. might just need to double check everything behind the unit. test the wires at the H/U and make sure ur getting a constant, and then the accessory. probly just something came loose
bpres9991
Giggin'
bpres9991
Kansas City, MO
southwest713
