Inside Boxes...
mdf isnt porous.
It isn't, then why does it **** up paint and anything else you put on it?
It is porous.
And there really isn't a need to seal the inside of a box with polyurethane or paint or whatever else, but it can't hurt. Sealing it inside or out would help if you spill water on it or other liquids that would absorb into the mdf.
applying resin is basically another form of bracing, it makes the walls stronger and more ridgid (less susceptible to vibrating), its the same idea as if you double walled your box, it would be stronger and lose less due to lesser vibrating and flexing of the walls. and since it would lose less "power" it would be louder. but we're talking tenths here.
but really i could care less if you "believe" it or not, you seem like an ignorant ass anyways :-D
So you're giving advice without having any proof to support it? That makes ME the ignorant one?
Come use my TL and show me...
Just when you think you're humming along... and... hmmmm happens!
22
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
OK, so turn your music on at moderate listening level and unplug the battery/alternator and see how long that capacitor keeps things playing...
19
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
827
95Prober
95Prober
Canada
gunny86
    May 12, 2024
Brendon Jenness
    May 11, 2024
