MXcarAudio
ok, i was goint to get soundqubed hds300 but they are sold out, can you guys suggest what will be an alternative just new prices or re order around the same price range thanks
Not sure what ir price range is but i xfl 15s are 215 shippedok, i was goint to get soundqubed hds300 but they are sold out, can you guys suggest what will be an alternative just new prices or re order around the same price range thanks
the qpower deluxe 12 are not bad for a very budget build not sure if your being sarcastic on your comment but this is not comparable with soundqubedQPower Deluxe 15s.. 3" coil.
do you have experience with the qpower? 12" is 2.5" coil as well.. not a fair comparison since we are being technical. 15" Deluxe for the price gets down broski. Not sure if you're just posting to post or... well i'm fairly sure you are. It was a suggestion, let's leave it at that. i've had more experience with AQ than most on the forums. had two of the first HD3 protos ever.. and two AQ20ks. I moved on for a reason. 800+ feedbacks later.. i'm fairly certain I know what to recommend for a budget 15. dc level 3 suit you better?the qpower deluxe 12 are not bad for a very budget build not sure if your being sarcastic on your comment but this is not comparable with soundqubed
I do have experience on qpower deluxe 12's, i just dont think the 15's are in the same level as the other 3 inch coils that is the price bracket of $150. but thanks for suggestingdo you have experience with the qpower? 12" is 2.5" coil as well.. not a fair comparison since we are being technical. 15" Deluxe for the price gets down broski. Not sure if you're just posting to post or... well i'm fairly sure you are. It was a suggestion, let's leave it at that. i've had more experience with AQ than most on the forums. had two of the first HD3 protos ever.. and two AQ20ks. I moved on for a reason. 800+ feedbacks later.. i'm fairly certain I know what to recommend for a budget 15. dc level 3 suit you better?
i'm ranting at this point because you seem to hold SQ in a throne regard.. plenty of better for the money, and for the money.. I offered an alternative you seem to not know much about or don't care.
/my 2 cents.
You just dont understand.I do have experience on qpower deluxe 12's, i just dont think the 15's are in the same level as the other 3 inch coils that is the price bracket of $150. but thanks for suggesting
