Incriminator Audio reps/nick w/e
off topic.. how do you find out your "output voltage" that you should set your amp to if you dont have a JL amp??
Multiply the rms watts you want to run times whatever ohm load it will be on and then find the square root of that number.
Example, for a kicker 2500.1 I would do 2500(watts) times 2(ohms) equals 5000. The square root of 5000 is 70.7. You want 70.7 volts.
multiply the rms watts you want to run times whatever ohms load it will be on and then find the square root of that number.
example, for a kicker 2500.1 I would do 2500(watts) times 2(ohms) equals 5000. The square root of 5000 is 70.7. you want 70.7 volts.
someone should make a tutorial of this.....showing exactly how to do it...
I may actually do it one day.......
lambo37
lambo37
SD
BobbyDD
