Incriminator Audio Death row D1 12's
HomeGrown
8.5 out of 10 they are used and are still mounted
light paint smuges on basket
had these since April
8 Spoke Black Cast Basket
3” 4 Layer Flat Wound Aluminum Voice Coil
Dual Black Progressive Spiders with Woven Tinsels Injected Pulp Matrix Fiber Reinforced Cone Multi-Layer Foam Surround Triple Stacked Magnets with Black Nickel Finish Interlocking Aluminum Spider Spacer Assembly CILD - Center Interlocking Dustcap ADC - Air Driven Cooling Nickel Plated Push Terminals Wrap Around Rubber Gasket 1000 watt RMS Rated RMS power Handling: 1000 Watts MAX power Handling: 2000 Watts ohm Load: Dual 1 ohm
FS: 37Hz
Qms: 5.78
Qes: .49
Qts: .44
Mms: 205 g
Cms: .09 mm/N Sd: 480
Vas: 29 L
Spl: 86.9 dB, 1w/1m
BL: 16.4 TM
XMAX: 24MM
Outer Diameter: 12 3/8" Mounting Diameter: 11 1/8" Mounting Depth: 7 5/8" Displacement: .15 cu. ft.
375$ plus actual shipping
exact shipping to be paid by buyer
will get new pic if needed with username if needed
HomeGrown
HomeGrown
michigan
blobb454
